Recording parameter tweaks via usb midi
edited June 2014 in General
Can I record these into my DAW? Not seeing midi activity in ableton when changing parameters in real time though... Is this a non starter?
  • I dont really understand what you want to achieve. Do you want your daw to record cc when you turn the knobs? I guess you can't.
    You can send CC's from ableton to tweak the lxr ( an then have more than the lxr's sequencer with the 2 plock per voice) and have some real nice things.
  • yeah, recording cc from LXR knobs into ableton is what i wanted to do... guess i'll need to map them to a controller instead.
    Is this a feature that could be achieved with future firmware releases?
  • Right now CC messages are not transmitted. There was some talk of adding this, and I will probably attempt it when I get more time to write code (unless someone beats me to it).
  • +1
    It would be really cool for DAW-based productions to be able to record the knob tweaking.
    So, feel beaten. (Just kidding) :D
  • Yes Rudeog, please! Combined with a ctrlr based editor, LXR would be beautifully integrated...
  • it would be so great! personaly i plugged a Quneo to the lxr so i can control a lot of parameters in different tracks at the same time, so it would be very great to be able to record it into ableton :)))
  • Hi all,
    I would like to "up" it because for me is the only main missing on the Lxr to use it in an home studio environnement !
    Since i sequence the drum machine with an mpc 1000, it would be so nice to be able to rec the automation, knobs movements from the lxr into as is possible with others synths...
    Does it looks like possible for a future...?
    Thks ;-)
