I built the LXR the other day and it sounds fantastic!
The problem I have is that on the trigger extension I am only getting a signal out of the first trigger. From 2 to 7 there is no output.
As far as I can see everything looks OK but I obviously have a bad solder or part somewhere. I'm hoping that because the first trigger out is working but the rest aren't that you'll be able to tell me where to check specifically for the bad solder/part.
I had a few people that only installed it for the first output, but the selection is per channel.
without a jumper the channel won't work.
