is it possible to copy from track 1 to track 2 ? and how? in the same way i would like to copy track1 from pattern 1 to track 1 on pattern 2, but i dunno if it is possible ???
It is possible to copy sequencer tracks and patterns to another position.
Press and hold the 'Copy' button. Its LED will start flashing, indicating that the copy mode is active.
Select the source data by either pushing a voice button (track copy) or a pattern button (pattern copy). The source data LED will start flashing.
Select the target. press the voice/pattern button you want to copy the source data to. As soon as you select the target the data is copied (overwriting existing data in the destination!).
To abort the operation, release the copy button before selecting a target
This can be misunderstood. WHen you copy a track to a track, it copy the step, not the parameter's voice. I guess you can't copy individual voices to a pattern. it's the all pattern, and nothing else.
About that, a nice copy feature would be the step. BE able to copy a step to another step in the step mode ( Plocks, midi note velocity etc) woulb be great for fast editing
flashing.
