Hi!
After playing with the unoficcial firmwire, I just try to reupdate to julian's firmwire and i can't.
i can read
bootloader v1.2 and them the lxr show chinese weird characters...First time i see that and only after tryng to update.
SO i Tried to
reformat my sd card (fat 32)
re download all the sd card image
try to upload older julian's firmwire... None of this work
ANd i can't update to the fusion new firm too
If i try an update without sd card, i get chinese caracters too
Egnouf suggest a on/off plug problem in his topic
Hum, It happenned to me to see Chinese characters.. it was due to the fact that I did not have a ONOFF switch on the machine.
I
was using my LXR directly to a power socket no OFF, no ON, direct
electricity connexion... not good, many times (1 out of 3) I add to
disconnect and reconnect the LXR power socket (chineses characters).
I added recently an ONOFF switch and I don't get anymore this issue.
Can you try the following:
1- Get a plug that has a ONOFF button.
2- Put your LXR power in the plug but not in the LXR socket (you will do this later).
3- then switch on the PLUG (1)... wait few seconds
4- then plug the cable of your power supply inside the LXR
Switch ON.
I
guess doing this you will give enough time to electricity to come to an
certain average.. well, I am not good in electricity!!!
I don't know if I am clear, but I can tell you that I can switch from Julian'code and mine without any issue :-)
Waiting for your feedback.
Can anyone confirm before i buy a cheap plug with a on/off button?
EDIT: Now, no more chinese signs, it' just that the bootloader start and stop after 2 seconds, them the lxr start normally, instead of update.
THANKS!
no?
I try without the mainboard today, chinese as well. I'm very sad
Maybe an AVR problem? Do you have to control some soldering point before try to change it??
Chinese characters are a sign of an unintentional reboot. :-/
just to recap:
it only happens while trying to update?
AVR sits tight in its socket?
You just see the "bootloader v1.2" and then it crashes?
besides updating everything works fine?
It's YES to all.
It's doesnt really crash because i can use the lxr after that, even with the chinese. It just show bootloader v1.2 and then boot normally/ or show chinese characters...
Besides updating, everything is working
so where you able to update the previous versions?
either at the AVR or near the P2 connector for the mainboard.
this line restarts the cortex during the update process. otherwise it is not used.
So if there is a short somewhere it could crash the AVR during the update (wild guess)
red/green just means the trace is on the top (red) or green(bottom)
i would just make sure that the 2 yellow highligted pads make beep and that the pads don't beep/have no connection to any pads next to them.
For example make sure there is no connection between the NRST and the (AVR_)RST pin on the P2 header.
NRST resets the mainboard and (AVR_)RST the AVR
so a short between those 2 pins would also reset the AVR while it is trying to update the mainboard.
Ok i need to recheck in depth tonight since i did this during my lunchbreak in a hurry but,
-Continuity between the highlighted pad.
-No continuity between NRST and AVR RST line and pins arounds.
Sometimes, i get an upside/down menu instead of the chinese characters.
Thanks Julian for your help!
