[Coding] force the LXR to refresh the sequence step values ?
edited May 2014 in General
Hello,
i have created a prefilledpattern function (you can choose between 72 pre defined drum lines), it works fine !
So...
i setup a special knob that everytime you turn it, it fills the sequence with a pre defined drum line (1, 5, 9, 13 are filled for instance).
if i want to see the new sequence on the steps i have to switch pages !
here is my code:
// rstephane : My prefilled pattern
void seq_setPrePatternFill(uint8_t voiceNr, uint8_t msgdata2)
    uint8_t i,maxsteps = 16;
    // clear current pattern in the memory
    seq_clearTrack(voiceNr, seq_activePattern);
    // we fill the track
    for (i=0; i<maxsteps; i++)
          if (prefilledPattern[msgdata2-1][i]>=1 && prefilledPattern[msgdata2-1][i]<=16)
            seq_toggleMainStep(voiceNr, prefilledPattern[msgdata2-1][i]-1, seq_activePattern);
        else
            frontParser_updateTrackLeds(voiceNr, seq_activePattern);
            return; // we arrived at the end of the steps that are ON so we quit.
i think, the solution is in the command:
void frontParser_updateTrackLeds(const uint8_t trackNr, uint8_t patternNr);
but this function only switch LEDs if they are ON :-)
what shall i do to light off leds ?
cheers!
