Blank Screen When Changing Modes
Some times when you change editing mode the display goes blank, for example when I've edited in step mode and try to return to voice mode. FW 0.15
  • yep it's the same as well here
    the screen displays data again when i touch one pot
  • does this happen as well with the screensaver turned off in the settings menu?
  • ok, I will look at this on the weekend
  • okay, i think i got it.
    the blank screen occurs when you are on page 2 of the menu in step edit mode. when you change back to voice edit mode, you end up on page 2 of the osc page, which is non existent.
    will be fixed in the next version.
