I can't seem to receive MIDI clock through the usb jack. I can get it to work through the MIDI in port... I've got the global bpm set to 0. When I plug in the usb cable, windows recognizes it and installs drivers for it. Any thoughts?
Maybe you have a short on the USB Jack, see this Flickr Album There are 2 Pads benath the USB Jack that might cause irritations, maybe you desolder the Jack, put a piece of Tape on it (the red stuff in the Pic) and resolder it.
This same problem has now creeped up again...I have great sync through MIDI, but none through USB. I've tried two cables now, and it seems like LXR just isn't sending or receiving through the port.
EDIT: It seems like it was due to being plugged into my USB hub not directly to the computer.
A hub should be transparent for any kind of information and since USB is digital you either have a Signal or not. There is no "strength" of Signal besides in the physical layer....
I'll put USB makeover on my todo list.
but I think i never tried it with a hub.
