Hi!
I just gotta say, this is such a cool project! I'm a musician and programmer and this is one of my first ventures into electronics, but it's fun and I'm gonna be such a proud owner of an LXR when I'm done.
I hope someone can help me out of this, I'll be so sad if I can't finish this! But I have a good store nearby and if someone understands what's wrong I hope it'll be fine.
On bootup I get the green voice LED instantly and I get informed about bootloader being of version .23. Then the display tells me "SD card not detected!"; I have an SD card inserted. It's formated to DOS FAT32 and unpartitioned with all the files from
http://sonic-potions.com/public/SdCardImage.zip unzipped into it. The encoder and the leftmost three pots work fine.
First 7 LEDs in the sequencer light up if I hit their buttons (first one seems to be a bit broken, so I'll try to get a replacement for that one - it doesn't click and is overly sensitive). But the start button does nothing.
I've also noticed that I don't see a leg sticking out on the topside where the mainboard leg labeled "NRS(?)" (6th leg, right under MIDI Out leg). If this is the problem, how do I fix it? But this can't cause both the SD card and the LED problems, right?
Ideas?
Best regards,
Love von Melen
check the soldering at the IC HC4050.
SD card not detected means it can't find a SD card at all. So it has nothing to do with how the card is formatted.
the replacement network seems to be the right one.
I don't completely understand where the 'leg' is missing. On the small mainboard or the big frontpanel?
Are other buttons working or only the first sequencer buttons? there might still be a bad solder joint somewhere in the hc165 chain. the sequencer buttons are the first in the chain. if there is a bad connection all the following buttons won't work.
You can find some instructions where to measure in the troubleshooting section in the wiki http://wiki.sonic-potions.com/index.php/LXR_Troubleshooting
SD CARD"
Ok
This is the way you have to count the pins
did anything get hot or smell funky?
for now it is not important.
first we should get the rest to work, then we can figure out whats wrong with the missing leg/pin.
Now I feel kinda scared. Is my soldering technique so bad that there's just that much interference between the buttons? I can't see anything wrong, looking at the solder, but could it be the PCB got overheated or something?
As long as there are no traces scratched. but that could be fixed with a piece of wire too.
I think this is a short somewhere or a cold solder joint on the 165 ICs.
Hehe, I forget to re-attach the mainboard from time to time, too.
You feel always stupid after wondering for 5 minutes why nothing works anymore
regarding the last sequencer buttons - check the connection between the highlighted traces on the following picture:
these go to step 14,15 and 16 and should have no continuity between them.
Is the last sequencer button still not working porpperly?
then please measure also the continuity between all 3 of those pins of the 165 (pin 11,12,13)
they should have no contact to each other.
could you systematically check these button groups
and report the first group of buttons where one is not working.
this helps to pinpoint the location of the remaining issue.
the thin is that the 165 ICs are connected in a chain. so if there is a loose contact or missing connection or a short somewhere, the following buttons in the chain won't work propperly.
here is the connection for button 8
and here for button 10
are the ICs all seated propperly in their sockets? Pushed all the way down?
It seems I had shorted the Voice 1 button to its' LED. Such silliness!
If it is bend under the connector it could short out its neighbour pins.
can you measure if the missing leg has contact to the mainboard?
otherwise I'd say solder a cable from the pad on top to the mainboard nrst pin (where normally the leg from the connector would make the contact)
This solution will not be pretty, but removing the whole connector to look for a bend pin will be quite difficult without the propper tools and without damaging something
If the NRST pin has no contact, firmware updates won't work. Other than that it is not used.
load/save button could be a bad conenction to the 10k network.
When the button is pressed it is connected to 5V. When not pressed the input signal is 'floating'. That means it has no defined state which is bad. So to give it a defined state (off or GND) the 10k resitor to GND is used to 'pull it down'
how much do the pots influence each other.
are we talking just a little change/jitter of 1 or 2 numbers or is one button controlling the others over a wide range?
Leaded or lead free solder?
about the pots... what power supply are you using?
Maybe it has not enough mA?
left pin of the pots is gnd, right is +5V and the middle goes directly to the AVR ADCs.
