Custom enclosure
edited March 2014 in General
First post here, so first of all hi everybody!
I finished building my LXR about a month ago and so far I've had a blast.
Anyway. I thought it needed a nice enclosure, and 2 weeks ago I started drawing on a custom front panel.
I wanted the box to slope and go as low as possible in the front, so had to mount the pcb on the front panel.
Now it's almost done and I really like it. Only needs some diffusers for the led holes and maybe a bit of graphics
If anybody is interested in the .fpd file, please let me know, and I will find some way to share it.
Cheers
«1
  • Hi, this one looks really nice. I like the tilted style, the real deal for a drum machine. Is this frontplate made by Schaeffer ?
  • Thanks, and yes the frontplate is Schaeffer.
  • I would love to have my LXR looking like that, and verily interested in this .fpd file of which you speak.
  • looking good! how did you make the wooden body?
  • Couldn't attach it as a .fpd, but zipping it helped I think.
  • Looking good! I did the same angled design with my all-wood case and I think it help a lot
    This is the point where Elektron should just buy out Julian and buy your case design and they could produce their best drum synth ever...
  • Wow! Really nice work! Are the knobs from an Elektron device?
  • It looks so much like Elektron. Great job!
  • Thanks guys, glad you like it.
    The body is made from an old piece of rosewood I found. The rough cuts were done on a band saw  and finished on the disc sander. Then the pieces were glued together, sanded and finally waxed.
    And yes, the knobs I stole from my octatrack. They are really nice, but I think the octa want them back though :)
  • It is so gorgeous and I am jealous :)
  • beautiful.  i think you can order more of those knobs from Elektron if you want to keep them on the LXR.
  • Nice! Great job!
  • wow looks like an elektron
    looks great
  • Sounds better though :)
    @vasculator, yes I was considering that as well. Thanks
  • How have you managed to change the angle between the top surface and the rear of the machine?
    What i mean is -
    The I/O is on the main board, so at 90 degrees to the work surface, whilst, on your machine, the rear is at <90 degrees to the top?
    Ive considered changing from pcb mount to panel mount, but there is still the SD card to 'worry' about! : )
  • I guess the angle between top an rear is still 90 degrees (see attached image). Looks very nice!!! I like to see more details about the case, also. Would you like to post more images about the case? How did you make the bottom and the rear panel?
  • @bassFant you are spot on. Everyting is still 90 deg to the front panel. Only the bottom is angled, making the whole thing lean a bit forward, which I realy like.
    I'll post some more pictures when I have finished the last details. Right now everything is taken apart. Trying to find a better solution than ducktape for making the caps snug tight. Any ideas?
  • I used blu-tack (or whatever it is called in your part of the world) - worked really well. Just made a little ball to cover the top of the switch then put the cap on
    this stuff: http://en.wikipedia.org/wiki/Blu-Tack
  • Thanks husker, I'll might give it a try.
    BTW in my part of the world (Denmark) that stuff is called "Elephant snot" (insert animated facepalming yellow smiley icon here) Don't ask why.
  • Good tip with the blu tack!
  • I never used this blu tack stuff.
    Does it stay elastic or does it dry?
    Is it something i could provide together with the caps in the kit?
  • ha - my wife had some white tack left from ireland.
    I just tried it and it seems perfect! =D
    I think I will try to get some to add to the kits in the future.
    No hassle at all applying and the knob sits real tight now.
  • cool :-)
    mine came from my wife too - I use it quite a bit in the 'studio' too as you can use it as feet for music gear that slides around, or wobbles slightly
  • I thought that's what the gum was for!?
  • Wow the pictures look so georgous, at first I thought it was some kind of 3D modelling work.
    Very Elektron-ish indeed but I guess that the knobs help a lot in that regard...
    Anyway, excellent job, I wish I had the same skills !
    :^o
  • Hi Just,
    this looks supercool!
    Can you maybe also post some Pictures of the back and the bottom?
    And the size of the wooden parts?
    Thanks a lot!
    noise
    @newnoise The wood is 12mm thick and the overall size is W:287mm D:148mm. The hight was freestyled, so not sure about that. I build the frontpanel based on the 12mm wood, so everything is real tight and there is only like 0.5mm gap between the wood and the pcb. This way I avoided a huge amount of emty space around the edge.
    Right now it is taken apart because I am replacing the led's so they will go thru the holes and align with the surface. When everything is back together I'll post some more detail pictures.
  • Wie looks awsome!
    How much was that panel from sheaffer?
