Request: add the Morph parameter as a destination for automation and LFO - would need to add another non-voice target (G for global?)
For LFO would probably need both presets to have the same LFO setup to avoid chaos (how does morph handle LFO parameters on presets currently?)
Currently the AVR handles the morph and a lot of data is transferred while morphing.
I have to rework the morph mechanism in an upcoming update, so maybe after that it will be possible.
The main objective for now is to fix the occasional glitches while morphing.
The LFOs are not affected by the morph, and only the LFO setting from the source patch is used.
Ok cool, will stick with the knob twiddling 'LFO' for now - morph in the context of a drum machine is amazing. Has anyone done that before?
On eproblem is that I an't hold 2 complete pattern sets in memory.
So it would only be possible between 2 patterns from the same set.
And one would need some kind of threshold value.
On the midibox seq each step can have a treshold. When the morph parameter is below this set threshold, pattern A is played, if it is above, pattern B is played. This allows you to define the transition between the 2 patterns.
I can not think of a really straight forward way to implement this UI wise. Only way I can think of would be to disable the probability and use it as a treshold parameter. But I think this swith would be rather confusing.
but lxr is so much better
