[solved] Feature Suggestion: LFO sync from external MIDI clock
As pointed out in this thread the LFOs won't sync to an external MIDI clock (i.e. from the DAW).
The whole LFO functionality of LXR is an important feature IMHO so I'd love to see this working.
TY! ;)
  • I'll look at it.
    should be something really simple.
    probably the calculated midi tempo just isn't forwarded to the LFOs...
  • ok I just tried it.
    you are right. the sync is off.
    it seems that it is syncing to the external midi clock, but somehow in midi sync it is much too slow!
    will investigate ;)
  • ok, I found the bug.
    I used a multiply instead of a divide when calculating the sync BPM for the LFOs.
    So the synced tempo is currently way off.
    I will upload a fixed version later today.
  • fixed in the latest update 0.32
  • edited March 2014
    TY!
