Loading pattern/kit with external signal like MIDI
Hi everybody! I'm a new french LXR user !
My Lxr is not even build but I have a question about Loading "pattern set" / "kit". Indeed, is using the "load/save" function on the LXR the only way to load another "pattern set" or "kit"... Is it possible to use midi signal for exemple, to change all my preset synth from all my different synth with the same midi keyboard or midi sequencer !
Thanks and excuse my poor english !
Teddy
  • I think it's not possible, yet.
    But may be implemented in the future.
  • It is not possible to do that at this point. What you can do, though, is to switch to a different pattern within the pattern set using midi CC.
  • Thank you Rudeog.
    Cool idea ! But that's not a solution for a complete live. If I change tempo, pattern set (to have at least 5 pattern to make change during one song) at least 10 times it can be really complicated... I want to stop using a computer and only use hardware so I want to use each features of each synth I use... I want to use the LXR as midi master for the most sequences and I'm looking for a solution to be fast as changing song...
    The fact that it's possible to load a pattern set in background is really cool for me for exemple !
    Thanks a lot !
    Teddy
