LFO sync?
edited March 2014 in Troubleshooting
While working on my track for the LXR compilation I noticed that I can't get the LFO synced to the MIDI clock coming from the DAW.
I set LXR's BPM to zero and the patterns are perfectly in sync, except for the LFO..
Anyone else having the same problem? Maybe I'm doing something wrong.
Apart from that I'm baffled by the LFO's possibilities. Big fun to run 6 LFOs on one voice. :->
  • Did you set the sync option in the LFO menu?
  • Yep, I just tried it without external MIDI clock in and it works perfectly.
    This is kind of a bummer as I'm using the DAW as clock master.
  • Let me guess : Ableton ?
  • Yes it's Ableton. Does LFO sync work with other DAWs?
  • Cannot check it yet, as i am refurbishing the studio and everything is plugged off.
    But Ableton sometimes shows weird behavior when it comes to sync external gear.
    Hopefully i will be finished by the end of the month, then i will perform a check with Logic, Reaper and (hopefully) Bitwig. They finally got my interest - even that it looks like they do not support the HUI protocol right now.
  • Ok I just downloaded and installed Reaper -> same problem. Everything is in sync except for LFO.
  • Then it may be something we should point out to Julian.
