I have the Trigger IO extension board and would like to add DIN Sync. For this purpose I intend to build a simple adapter cable (2x 3.5mm TS --> 5pin DIN):
For DIN Sync In I'd like to use Clock In and Reset In.
For DIN Sync Out I'd like to use Clock Out and Reset Out.
The first problem is: I need a clock rate of 24 ppqn (yet there are 1, 4, 8, 16 and 32).
The second problem is: I need a high Reset output when the sequencer is running (yet it is reversed).
Any chance to add these settings?
Could still take a while though
24ppq should be possible, it just isn't so straight forward as the available rates, since the sequencer is running at 32ppq internally and 24ppq is no simple divide by 2 ratio. That's why I left it out in the beginning
But I think I could use the code from the midi clock out, that should be 24ppq afaik.
I put it on my todo list...
24 ppqn for the clock input and output would be really usefull. And 2 ppqn would also be great, since the Korg monotribe and the volcas use it.
