Hi there! I built the machine over the night and it's amazing!
But another night I spent on exploring features and challenging the manual. Everything works excellent, but only thing I can't get done is loading Patterns to the Pattern Set... It loads the new Pattern in the first Pattern location (say, Pattern1), and, when in performance mode I activate Pattern 2, it's empty. So the question is - how EXACTLY sould I load a Pattern to other 7 Pattern locations?
And then how the Pattern Set is Saved and how it appears in Load Menu so I can Load it back later? The manual gives just generic info that all patterns in the set are saved in one file.
Please help someone!
Thank you!
If you have programmed only one pattern and saved it, you get only this one pattern when you load the set.
If you have programmed two patterns and saved them, you get the two patterns when you load the set.
And so on....
You can't load a single pattern to a particular slot.
Press and hold shift button.
Use the 8 select buttons to select the pattern you want to view/edit.
Release shift button.
