LFO panning : Bug on 0.27
Hi there,
The LFO seems to have some trouble when applied to "voice panning" destination :
 2) On voice 1, 2 and 3, it only goes from left to center (with the MIX pan parameter set to 0). In order to have it covered the whole left-right spectrum, you have to turn the MIX pan parameter to +64. If turned to -63, it simply get stuck on the left side.
1) On voice 4, 5 and 6 it doesn't work
  • I noticed this in the code the other day. Voices 4 5 and 6 are not wired up to any pan modulation, and the first 3 only pan left. If it's easy enough to fix, I'll push it with my next custom feature (which should be within next few days).
  • Great to know the issue has already been spoted in the code ! Thanks for your feedback.
  • regarding point 2:
    this is due to the way modulations are handled at the moment in the LXR.
    To simplify the coding quite a bit, modulations are done like this:
    'actual parameter value' * 'modulation value'
    so the parameters are always modulated between 0 and the set value.
    to point 1:
    i found the problem. I implemented the pan handling for the drum voice (1-3) but somehow forgot the copy the fix to the other voices. I will fix this for one of the next releases.
  • Ok, I understand point 2 and why you have to have a set value at +64 to have the full spectrum.
  • panning value is actually 0 to 127 - (but is displayed as -63 to +64 to be helpful)
    The LFO ranges between 0 and 1 and simply multiplies the panning value - so the maximum value is whatever the parameter is set to, so to pan full right you need the value set to +64 (127)
  • just uploaded another firmware version (0.30) that should fix the pan mod issues for snare, cymbal and hat voice
  • Whaou, that was quick ! Cheers, I'll try it soon.
  • I've pulled this fix into the my custom firmware now.
