Perf - Roll bug v0.27
Hi folks, I just discovered a little bug in the current (0.27) firmware.
Start in Perf mode
Press a step button 1-7 to trigger a roll.. keep holding the step button...
... now switch mode (press Voice, Step, or Load/Save mode button)... and then release the button for the roll.
Roll gets stuck :)
Maybe this is a "latching" performance feature... in which case the bug is that the step button LED should light up to indicate which voice is rolling, when you switch back to Perf mode from the test above.  currently. all LEDs are dark, so you have to stab around to find the right button to cancel the run-away roll.
Otherwise, I would suggest a flag "voice is rolling" ;) per voice... set it when you start a roll in Perf mode... then, any time you release the Step 1-7 button, regardless if you are in Perf mode or not, check this flag and if it's set, cancel the roll.  Or maybe there's already a mechanism in place which simply needs a small tweak... :)
  • Yeah i notice that but didn't thought it's was a bug. Despite the led indicator missing, that's a great feature thats allow you to make rolling break then go to the voice menu and tweak it.
