Hey All -
Loaded up the firmware to try using my own samples. Everything worked well, got the new Load Samples menu, loaded up some samples (from the Akai site) and they show up in the Oscillator waveform menu. When I select a sample, though, the LXR freezes. LEDs that were lit stay lit, but pressing any button does not light any LED and the menu does not change. Reboot, all is well until I select a user sample then same problem.
Mike
not sure what happens if samples > the max filesize are loaded (i think it is something around 490kb)
I'd try to re-install the firmware and try to load a single sample (just to be sure it is not too much data)
but normally this should not freeze the UI, since most of the magic happens on the mainboard. The UI inly gets a new limit set for the number of available waves.
I'll have a look into the code.
