Hi!
I just receive my LXR!
And finished all the soldering.
But I've continuity between 5v and Grd.... I checked again and again and again and again every solders, polaraity, steps, but I can't find a short between both of it.
Is there any other way to have a continuity? Is there other classic mistake that I maybe did? So frustrating!!!
I made my test with the resistor mode of my multimeter (I don't know if it's good, but it's the only way the needle move when the pointers are in contact.
And I test the circuit once the adaptator wired. I have a good 5V.
Any idea? I so want heard it's fucking sound!!!! haha
I assume your multimeter does not have a mode that makes a beep if the 2 probes touch?
you can also just measure the resistance between GND and +5V
I measure around 2kOhm.
If there is a short somewhere, you will probably measure something in the range of 0 to 100Ohm (depending on the size of the short
problem still there when you change kit?
