Hey guys!
I'm happy to try first, so be gentle
Here is the first patch named CLUVA i want to share. it's like weird simple house kit and pattern.
It's a performance mode i saved with the rudeog firmware (thanks again, what a great feature!).
It's two chained pattern (1 and 2) The others are just experimentations, not really achieve what i wanted.
Please have a look a the "cowbell" (not really a cowbell, but that only how i can define it) in the voice 3. I like to use the lfo to change the samplerate, please play with that! I use also the pattern generator mode to jam with it
The second "tip" i would like to explain in this patch is the bassline on voice 2. I use the lfo in voice 6 to retrigger the filter frequency, so if you play the mute and the lfo rate of the voices 6 and 2 , you can jam or make some little breaks.I also like to play with the decay parameters.
The others voices are common. I can't remember from which kit i started and how many time i tweak it, so it may sound like another kit and i'm sorry if it is.
http://paf.im/mAFWj(Sorry i cant upload it on the forum... Julian can you add the prf files to the authorized files so we can upload it directly on the forum?Thanks)
SO i hope you will try it out and have some fun with it, and that you discover a feature you didn't know. PLease share your patch too, with rudeog firmware it's really easy !
