Yesterday I finished my soldering. Everything went fine with the voltage tests and even got the normal screen after plugging in. Most of the buttons were ok and the diodes worked for every button (except one from the 16's but I solved that). In power on mode the start button didn't effect anything, but worked before with the diode. That means I had no running light. Then I read in another thread here to check the start button and its solder. I did that, but after resoldering the screen got problems. It shows squares and a 23 (!) and some chinese letters (real ones ; ) ).
I reheated the screen contacts just in case but it remains the same.
I have one thing to say, I used a DC 7,5 -or 9 V but with only 300mA, it worked so far but could that be a problem when at least 600mA is required?
The board at the start button solder from the bottom looks a bit soapy from the flux, I hope I didnt destroy any subway connection there?!
Or could it be a problem with the the Atmega?
Thank you for any help!
Of course Ima get the 600mA DC one tonight.
http://forum.sonic-potions.com/discussion/142/no-led-blinking-after-soldering-but-only-strange-sings-on-lcd-solved#Item_34
...and updated, it's working again. No lights are running but I think its apower problem. Gonna try it with the new DC...
:^o
