Pattern Set
If I program say 13 different patterns and save them each using a different pattern name on the SD card, how group I 8 of them
to a pattern Set x?
  • When you save a pattern its actually saving all 8 patterns, so there is no way to break it apart into a single pattern.
  • But only the first select button is lit theother 7 are dark. So I can not toggle between the 8 patterns
    using only the 8 select buttons. Is it correct?
  • You can toggle between them when in performance mode. Depending on your "follow" setting, you can edit them while they are playing. If follow is off, you have to do shift click to set the edited pattern.
  • So to clarify, there is the "playing" pattern and the "edited" pattern. The playing pattern can always be set with single click when in perf mode. The edited pattern can be set with shift-click in perf mode. If follow is on, the edited pattern will always be the played pattern.
