I just thought about the display mounting...
Maybe it would be easier to just use a longer pin header like this
It could probably be mounted from the top of the display and there would be no need to push the black plastic thingy around, since it is long enough to be soldered like it is. you could then just cut off the excessive top.
what do you think? is this easier than with the normal, short pin array?
on the 2nd batch it was quite stuck in place much more tight. :-/
I'll see if I can find the longer part.
after soldering it on one side i remove the plastic and then solder the other side. this way i am able to cut the individual pins in case i have to desolder it.
this way its also possible to push the plastic clother to the ends of the individual pins before soldering so that they barely stick out of the pcb. this way i don't need to cut them after soldering, but still have tiny solder joints that are not in the way of other components. (like with the midi jacks on the lxr)
Is it sturdy enough?
I'm just not sure there is enough space between the display and the PCB on the LXR since an angled display won't fit here.
i didn't find them at mouser nor reichelt when sourcing for preenfm2
Couple of questions. First, why not solder the display connector before mounting the MIDI ports?
How is the display mounted/secured to the PCB? It's not immediately clear in the instructions. Do you solder the pins to the display?
> Make sure to cut off the legs of all the parts below as short as possible, so that the display sits flat on the PCB. Then solder the display to the connector from the top.
Should I shield these connections by putting electrical tape over them?
Anyone have any recommendations on a fool-proof way to complete this step? It's the only one I'm apprehensive about (let me know if there's other stuff a beginner should look out for!)
