My LXR's audio outs are significantly more noisy than any of my other devices... Has anyone else noticed that? Not outrageously noisy, and nowhere near unusable, but if I turn up the LXR channel on my mixer while the LXR's plugged in but silent, the noise floor is pretty audible - a lot louder than my other devices when I turn their mixer channels up.
Is there anything I could do to get rid of some of the noise? Is this just my LXR, or is this a common issue?
Is the LXR using the same outlet as the rest of the equipment?
I think that could very well be the Problem: you have created a ground loop. Try powering the LXR from a dedicated, non earthed power supply, or try an audio cable with a lower resistance ground connection.
I had lots of hum from my LXR when I used an earthed powersupply, which also created a ground loop.
You could also try putting a common mode choke into the powercable to the LXR, e.g. this Reichelt Part: http://www.reichelt.de/Stromkompensierte-Drosseln/CAF-0-9-47/3/index.html?&ACTION=3&LA=2&ARTICLE=32283&GROUPID=3183&artnr=CAF+0,9-47
Basically, when my DJ controller and LXR are plugged into my PC, the outputs on both the DJ controller and LXR hum. When I plug my LXR into my LCD monitor (which has 2 USB ports, connected and powered by a USB type B cable), the hum disappears.
Both cables have ferrite beads, and I've tried other cables. Any ideas? Using my monitor's USB ports is not a problem, but I'm curious as to why it's happening.
