Hello LXRers
I in the process of building a small rig for out-of-the-box composition, and are right now locking for a nice drum machine. I am looking for something small, with an x0x sequencer and not machinedrum-expensive. However I am not a great fan of the minimalistic sound that analog drum machines usually creates, so what I wonder is; can you produce a more maximalistic sound from the LXR if you feed it the right samples?
And with maximalistic I mean in the same veins as the drums that was popular mid and late 80s. Some examples:
And the most extreme example of them all:
Take care every one!
However many of these sounds have their origin in early sample based machines like the Yamaha RX5 rather than analog machines like Roland TR808. So, perhaps my questions should instead be: Given that you feed it the right samples, can you make the LXR sound more like a Yamaha RX5?
There are also a lot of SampleBanks online for free.
The LXR is a lot about its sequencer, that is problably waaay more powerful and user friendly than that of vintage drum machines.
In short, if you buy the LXR you get : an awesome drum machine with its OWN sound engine that can also be used to sequence external samples (or load some with the latest firmware).
And yes the sequencer of LXR does seam to be pretty awesome, but so does the Beat707, which also is cheaper (since it is only a sequencer and need an arduino board to work). So if I am going to use an external sampler anyway, It might be worth to wait for the reissue of Beat707 instead, and that is why I am asking about the LXRs sampling capabilities
You can always use sample in your daw and sequence it with lxr or beat 707. But you cant use the beat 707 as a drum synth. So if you dont care about drumsynthesis take the beat 707
For the synthesis possibilies, they are very high et you can spend a long long long time using it without being bored. Since the firmware is in constant evolution, its more fun with the new firmware who goes out. If you are not "introduced" to synthesis, the lxr could really get you upset so keep your abilities in mind. You need to work the sound, i spend around 30 min per voice to get a sound i'm satisfied...ANd i know people who can spend really more time. Please, read the manual to see if you re not lost and can handle the machine.
