downgrade to previous firmware version?
edited December 2013 in General
My LXR has been showing some weird and erratic behaviour since the 27 upgrade. It worked fine up until the previous alpha release. Where can I get the previous version to make sure the trouble is indeed caused by the upgrade?
rvk
  • ha, i just posted a similar thing in the firmware thread.    I'm having problems w/ Drum 2.  its like scanning the .wav imported wave forms in the oscillator..   otherwise, it seems ok.
    What issues have you noticed?
  • the GIT repository goes back untill 0.23
    don't know if the direct link works
    https://github.com/SonicPotions/LXR/blob/6a3e20e3c5199cefae47ecebc7384acf7b6d9533/firmware image/FIRMWARE.BIN?raw=true
    if you view the FIRMWARE.BIN file on github, you can go back to previous versions using the "History" button.
  • Thanks Julian!
    The link you posted is to an older version, but I'll figure it out. thanks!
    Billieblaze: my LXR was just being weird. On some channels I couldn't select an osc waveform anymore, and sometimes a sound would just suddenly to staccato white noise for no apparent reason. One explanation could be that I've been integrating it into a large midi setup with ableton, and it might have been receiving stray midi cc messages.
    But I really don't have time to reproduce and document errors right now. Gotta be productive, and I already have an audio interface that's giving trouble because of an OSX Mavericks upgrade :'(
    Rvk
  • I kicked Mavericks for Mountain Lion, as Mavericks sucked in every way. I do not know any Pro using Mav in production environments, many tried and swapped back, as Mavericks nearly sucks more than Windows...
