Some time ago I built one lxr, the first batch, and I now have more time to play with it.
I think the value of the resonance of the filter does not work properly or I do something wrong in the modeling of sound.
When I move between the values 1 to 114, there is very little difference in sound (almost nothing), between values 114-115 there is a high change in sound. From 115 to 127 it seems that there is no change in sound.
The frequency value is correct and the filter modes too. The problem happens in all modes of filter.
The potentiometer works well because the numbering change correctly displayed when turning the potentiometer.
You may have something wrong with the pcb?
Some component may be failing?
There's something I do wrong to set the sound?
Any idea?
Excuse my English, I translate with google!!
So as long as the numbers in the display are correct, the filter will get the right values.
I can check the resonance control this afternoon. If the response is really that bad it should be easy to give it another control curve. Never noticed this myself, though.
If I remember right, the frequency control is much more exponential
