http://casperelectronics.com/finished-pieces/nova-drone/
I just finished building a Casper Electronics double Novadrone... This thing is super fun, probably my favourite DIY build so far just in terms of how much fun it is to sit down and play around with it without having to think about "composing" anything. Each column of knobs and switches is a drone voice with an LFO, with a whole bunch of input and output signal connections that you can use to connect aspects of each voice in all kinds of ways. The breadboard at the bottom lets you make arbitrary connections between voices, or even build circuits that modify the sound. Just screwing around with making random connections and jamming capacitors in randomly is incredibly fun. The RGB LEDs look great too. Really fun to play with, and it can make some really cool sounds.
I expect that playing around with this will teach me a lot about synthesis generally, and I'll probably learn a lot about what electronic components actually do in audio circuits from the breadboard feature. For people like me who learn by fucking around with things, this seems like a great learning tool - you can instantly hear the difference that adding a certain connection or component makes to the sound.
Reasonably cheap to build if you source the parts yourself. Cheap potentiometers from Tayda Electronics saves a lot over getting pots from mouser or whatever.
If you haven't built one of these things already, I'd highly recommend it. Prettiest PCB I've seen so far, too.
You'll need to tease-me real hard, how much money can I save from not ordering the kit ?
