Syncing issues with Reason
Using Propellerheads Reason as sequencer and syncing LXR in slave mode gives following problem:
At the end of an reason sequencer Loop, when the loop restarts the LXR stops playing.
Maybe there is an unusual/unconventional way of sending midi clock signals...? Maybe thats because LXR does currently not support midi clock continue?  In Reason there are no changable properties for midi clock signals besides selecting the midi out, so there is no chance from that side. Additonally, using Reason as slave and LXR as master also doesn't work. Reason even doesnt start this way...
But I got it to work flawlessly with the Renoise Tracker as Sequencer. So i basically works.
Not that I think the LXR has to work with every Sequencer out there, but this is definately a problem for propellerhead reason users out there.
If there is interest I can try to monitor the midi messages from Reason, and post some info
  • Yes, if you monitor midi messages, see if there are any midi continue messages. If so it might explain it (eg if reason does a stop and a continue)
  • I'll try to fix the sync with the fruity loops demo.
    hopefully it is the same problem for reason ;)
