So, to clarify, you can select which channel each track sends it's midi out data on, but you can't select a global channel for the whole machine (only receives on channel 1)?
The MIDI receive parameters have a few bugs. The LXR will only receive on channel 1. On boot up the voice channel defaults to 0 but receives from channel 1 and works. If you change the LXR channel to 1 it also works but now you can't go back to 0. If you change the receive channel to anything other than 1 it will not work. Also if you change the Drum 1 voice channel to something other than 1 it seems to disable the other voices that are receiving on 1.
I haven't sequenced external gear but from what I've followed on the forum the different MIDI channels are transmitted. Member rudeog also posted a customer firmware that adds some cool features for external sequencing.
