syncing problems,please help !!
edited November 2013 in General
Here is my problem.
I am trying to use LXR in FL Studio.
I can hear sound from lxr in fl studio,but cannot sync and cannot make lxr to play when i hi play button in fl studio(Midi Slave).
Anybody can help me with it please ?
Thanks a lot
  • after i press play in fl studio lxr doesnot start with FL ,i have to press play on lxr again and then it starts.
  • Okay if i change global tempo in fl studio it also works with LXR(it also changes lxr tempo)but still cannot make lxr to start together with FL studio! ! !
  • reading manual and it says that i have to set bpm on 0,i did it but same
  • okay i synced everthing but lxr sequencer doesnot start with fl together
  • How is the LXR connected to the computer?
    Is FL set to send midi clock and start/stop messages?
  • Lxr is connected via usb,my whole studio is connected in fl studio(bassstation2,minibrute,ms20 etc...)
    It works in ableton but not in fl studio
  • Lxr sequencer doesnot want to start with fl studio,ableton does normally.
  • How should i set fl studio to send start stop messages can u tell me ?
  • midi master sync is enabled in fl studio,but i donot know from where i can set fl studio to send start stop message ?
  • Hi see my other post entitled "USB MIDI sync issues...". There is a problem with FL Studio and there is a workaround.
  • SOLVED !!
    Thanks to rudeog !
  • so with the new "MIDI continue"message fruity loops (and i suppose reason too) are working now?
