Hello!
First of all i would thank you for this incredible drumsynth! It makes a lot of fun and the features and the soundengine are very good and special.
I love my LXR!
At the beginning i had some troubles with the firmware and the sd card, but after i sucessfully installed the 0.24 firmware nearly everthing is fine and works for me.
Here is my problem.
Sync with the midi ports is ok, but the sync with the USB port drives me crazy :-)) The tempo of the LXR Sequencer is much to fast. A 120 bpm sequence sounds like 200 bpm. This is unuseful for me.
I'm using ableton live suite 8.
My usb setting is: output usb midi sync - on, no other settings...
and i also can not sync ableton to my lxr by reverse setting (input sync on)
it would be very kind, if somebody can help me ;-))
cheers and groove on
HEX
I have seen a "double tempo" issue in the past with other external gear, and it was the result of a midi feedback loop (I was getting the midi clock sent twice which doubled the tempo). So I guess you could check to make sure you are not ending up sending it twice (like if you had both the din and the usb connected, not sure what else to check)
when i connect my LXR with midi i/o i use my firewire interface echo audio6 in LIVE. This works great.
Yes maybe the LXR interface on my computer cause this problem. Now i will try reaper...
Only the LXR USB Port has problems...
How do you like the bass-station2? I'm thinking of getting one (but as usual I am trying to justify the purchase. Too much gear).
Have fun and groove on...
In the end it is just like the hardware midi implementation, just another channel where the data comes in.
since I have the merge with rudeogs code finished, I'll try to sync the LXR to ableton via usb now...
same settings as you used.
Do you use a hub? (just guesstimating here)
Thank you for your answer!
I do Not use a USB Hub. I work with ableton live8. The USB Port is recognized in the midi-Audio settings on my Mac. The USB connecting seems to be "ok". Live8 lists the LXR USB is the midi settings. Also Reaper shows the LXR USB. In live the Sync is not ok - it plays about the double of tempo. In Reaper nothing happened, when i set the click to the usb port. Playing a midiclip in live is also buggy. Sometimes it works, but not stable.
The LXR Midiport I/O work great. Strange...
All my other hardware gear (Virus TI, Basisstation, ...) work ok, without any problems.
It would be very nice to solve this problem.
Have a great day ans thank you!
Hex
It would be very cool, if the Tempo in the LXR could be saved within a pattern.
Think about it ;-)))
I only have access to linux and windows machines.
I just want to find out if the problem is limited to hexs unit or a general USB problem.
regarding the tempo.
I think we had the discussion at another place.
best would be to save the tempo with the pattern, but don't change it if the sequencer is already playing.
otherwise you will get tempo changes if you load a new pattern set in the background.
Yes you are right. Tempo change is not usable.
Concerning the USB problem:
I bought a midi to USB (ESI midi mate II) cable today. One side midiport plugged in my Mac and two cables with midi I/O in my LXR. This works! No Sync/Tempo problems... http://www.thomann.de/de/esi_midi_mate.html
Therefor i think it is not a problem with my Mac.
What do you think?
Thx!!!
Hex
Should i validate the assembly of the USB Port?
Hmmmm....
I will report the result soon.
Thank you all for your assistance!
Hex.
i tried the LXR on my freinds macbook pro with Abelton Live 8 and the sync tempo problem is the same.
The LXR sequencer speed is too fast.
Best wishes,
hex
