I've been noticing that the pan and audio output settings on some of the voices get messed up sometimes, like I'll notice a voice is only coming out of one speaker and find the voice's pan set to "3", or the audio output is set to L1 or something when I never intended to change those settings... Probably nudged a knob when adjusting volume or whatever.
It would be handy to have a master mix menu where the settings affect all voices - maybe you could access this by going into the global settings menu, then pressing the 8th select button. That could bring up the mix menu that comes up for voices (vol-pan-sr-drv-out-len-ch), but any settings you change would affect the settings for all of the voices. That way you could make sure all the voices were panned properly or going out the right outputs without having to check each voice.
A master volume setting might also be nice.
Sent from my iPhone using [URL=http://tapatalk.com/m?id=1]Tapatalk[/URL]
some kind of global page, "mixer" page or something like the performance page on the ambika is a nice idea though.
some kind of sound parameter performance page is something I have on my mind for a while now, but I'm not quite sure what would make sense there...
When I understand it correctly, in order to have an adjustable master volume, I'd have to mod the LXR and add an output with a dedicated amplifier (like a headphone amp)?
I'm really new to electronics, so please excuse my silly questions
The problem I see with a master out control is the output routing.
You need 1 potentiometer for each output.
so you can either use 4 independent pots (4xmono)
or 2 stereo pots, but cant control the mono outs in dividually any more...
Thanks anyway!
A performance mixer page would be cool. In voice mode I'm happy enough since selecting the next voice will keep you in mixer mode for it as well.
I would still love a master filter!
Thanks.
