Hello everybody. I am sending MIDI note events from the LXR to my Nord Modular, the latter plays the notes with endless sustain/release. It's like there is not a MIDI Note OFF command. I think that I got that problem since I installed the latest firmware. Anyone else facing something similar?
http://www.kvraudio.com/forum/viewtopic.php?t=291892 (second comment down in the thread)
There are really no differences (from a programming point of view) between standards and conventions: if some convention is used enough to be called that, you have to support it just as you have to support the 'standard'.
In reality you don't _have_ to support anything, standard, convention, or otherwise. The only litmus test is 'does it behave as expected?', and both official standards and layman conventions contribute to the answering of that question.
I don't know if it is possible to include a Note OFF command in a future Firmware version but it seems to be the only solution to my problem.
There is a lot of evidence in this thread that it is not nearly as 'unconventional' as you are claiming. And from reading up on the topic, it sounds like not supporting Note On = 0 is just as unconventional as not having Note Offs.
There are also zero instances of the developer saying "No Note Offs!" Did anyone even say "Note Offs" are a bad idea?
No, we were just saying that its not as ridiculous to not have Note Offs at this stage as some people are trying to present it here.
(Edit: And I thought macMOE was on the side of reason here
You're going to have to work harder if you don't want to fall on the side of reason macMOE!
If it wasn't clear, I was also only trying to voice a rejection of the idea that this is due to sloppy implementation. It looks a lot more like 'incomplete implementation' from where I'm sitting. But then again it never even crossed my mind that we wouldn't be seeing major new MIDI features such as CC sends,etc. Maybe I have my expectations too high in that regard..
can anybody name a synth that actually uses note off velocity?. (like vca env release for example) i have never seen it in any modulation matrix or noticed it beeing used.
