Odd behavior
edited October 2013 in General
while enjoying my working usb, I went to load some samples to find that I couldn't load any.  I tried to re-install the firmware, but it now hangs on "updating 1/2"
If I power up the unit, it says it is running 24a, but the only osc choices I have are the standard ones.
  • Update:
    I deleted everything off the card, re-populated the card with sounds samples etc, and now it says all my kits are empty.
    I guess the bootloader hang has something to do with it...
  • make sure your card is formatted at fat32 i had the same problem and it was a crap sd card soon as i got a new one it worked fine.
  • I've kind of fixed it.  I've got all the kits back, but the sample folder isn't being recognized.
  • Call it solved. but I don't have the load samples option in the menu.
  • I think the v.24a that is in the latest firmware thread is different than the one in the beta testing samples thread.
    I just loaded the latter and everything is back to normal.
