I've just made my LXR portable... It runs fine off 6 rechargeable NIMH AA batteries, and I built a cheap headphone amp (search ebay for "RA1 headphone amp kit" - I paid $17 shipping included, or you could just build one yourself), and stuck that to the bottom of my case under the LXR frontplate. The amp has its own power, and two leads that I can plug into the LXR audio outs when I want to use the amp.
If you tapped the 9v before the 5v regulator before D1 and then inverted it using something like this:
http://www.madbeanpedals.com/projects/RoadRage/docs/RoadRage.pdf
Then you could have a bipolar 9v supply to run the headphone amp. If the headphone amp was small enough to fit inside the LXR then you could just wire it all internally and add a headphone jack to the back.
You'd need a 9v supply that could handle all this of course.
Sent from my iPhone using [URL=http://tapatalk.com/m?id=1]Tapatalk[/URL]
you could hack up something like tsv suggested, on a little bit of pearfboard. but simpler
basically lt1054 and a bunch of caps. depending on your input voltage you don't even need regulators.
not sure though if it is enough for the current, your headphone amp draw, but i think so - lt1054 gives 100ma max.
It needs +/- 5/18 volts. Could it run from the LXR DC socket ?
