Continuity test
Hi i did a continuity test and its not bleeping but it shows 1,199. Is this good ?
  • Is it beeping when you contact both probes ? If yes, then it is not good...
  • in this case it is good if it is not beeping. from the picture I suppose you are testing between +5V and GND.
    if it's not beeping all is good and you can continue.
  • It is defently NOT beeping .
    Many thanks !
