Hi Julian, great work on this little machine. I haven't had much time to play with it yet, but I'm loving how quickly you can just jam out an idea organically.
So a couple ideas,
Firstly, I wonder if it is possible to have tracks playing from different patterns at the same time. ie; In performance mode pattern 1 is running, I'd like to be able to trigger the snare track from pattern 2 but let the other pattern 1 tracks continue.
I imagine that holding down a pattern button, and then pressing the corresponding voice button could work from a UI perspective. visual feedback could be that any pattern that is involved in current playback is lit, and will count in like normal. I don't know if you can control brightness via software but if so you could have the "Primary pattern" lit at full brightness, and others less bright. The primary pattern would be defined as the last pattern triggered completely so long as a track from it is still running.
In a live/jam situation this would be useful I think, as long as you could keep track of what is going on.
Having said all that, This might be beyond the scope of what the sequencer is for, and if the software was not designed with this in mind it could require a bit of work. It may also break the pattern chaining logic. Anyway, just an idea.
Secondly, (and I'm sure this has been raised already) I'd like the option of pot-snap/catchup behaviour I know there are strong opinions on this one so to have it configurable would be good. As it is rare for the current actual pot position to line up with the value of the currently selected parameter I find the pot-snap a bit harsh when tweaking live.
I haven't looked at the schematics, so maybe pin count is an issue. But it seems that encoders would have been a better option here...?
thanks
