Good or Bad soldering joints?
Are these soldering joints good ? Its my first DIY kit so a litle feedback would be great.
  • Unfortunately the focus of this picture was in the upper left corner, so the main area of your solder joints is pretty unsharp. I would like to ask for a better picture, so we can give you a statement.
  • Maybe these are better pictures, i need daylight for good pictures
  • These are much better. There is nothing obvious bad, the solder joints look good by the first look. And the amount of solder used so far looks fair too. And as long as they are shiny it is a good sign that they are not cold joints...
  • Thanks for the support, it gives me a positive
    influence to start the next step .
  • You could clean your PCB wit isopropanol and than look again. I always find a couple of solder joints which look not perfect when looking at my PCBs from different views/angles. I've seen a lot of worse factory made PCBs, yours look mostly good. :)
  • I found these:
    Right Amount of Solder
    _____a) Minimum amount of solder
    _____b) Optimal
    _____c) Excessive solder
    Solderability
    _____a) Bad solderability of terminal wire
    _____b) Bad soldering of PCB
    _____c) Bad soldering of terminal wire and PCB
    source: http://www.elexp.com/t_solder.htm
    Seems to be a reasonable guide (just did some cross reading)
  • Very nice example , looks i did it just fine
    thanks for the support
  • edited January 2014
  • Yes its finished and evrything works fine .
