Assembly instructions are up
edited April 2013 in General
you can find them on the sonic potions page http://www.sonic-potions.com/assembly
feedback welcome...
  • yup, looks good ! Explanations are really good !
    \:D/
  • looks very clear to me
    surprised by the way the screen is mounted though - wasn't there another way?
    Like, exchanging the positions of the midi connectors and the core board?
  • great work! nice explanation
  • surprised by the way the screen is mounted though - wasn't there another way?
    The only way I could think of would have been to make the PCB bigger.
    I didn't want to put the display above the mainboard, since the analogue circuitry for the IOs is located on the mainboard. At the moment there is no digital signal running across the analogue IO section and they have a nice undisturbed ground plane.
  • Very nice. Am I missing something here but couldn't you just solder the MIDI connectors after the display connector?
  • It is very hard to cut off the legs of the display connector short enough to allow the midi jacks to sit completely flat on the PCB. Add a blob of solder and it is nearly impossible ;)
  • A possible solution , Dremel/score/file/cut a channel in the MIDI jacks? You can't damage any connections on the bottom.
    regards
  • yeah, sure. but what is easier?
    Dremel components to fit, or just solder the components in another order?
  • I was missing something... :-)
  • It's just like a shruthi.... display last...
  • Very clear instructions. Looks a nice easy build!
    8->
  • Looking forward to it!
    The iron is getting impatient...
  • edited November 2013
    Very good explanation for board assembly. The explanation is
    divided into steps to understand and execute assembly process properly. Images
    plays important role to understand the assembly process.
    circuit card assembly
