any ideas?
edited October 2013 in General
done with the build sees every thing is ok except I get stuck notes on the voice 6 and 7. any ideas in what it is.
  • does it happen with different presets? if yes: aymbe try reflashing firmware and test again.
  • haven't got that far. il try on break. would the sd card do it. I know the memmory on an mpc can completely brick it.
  • the sd-card should either work or give error message
  • if no preset is loaded (boot without a SD card) the hihat voice (6 and 7) have a much too long decay time.
    It is a bug in the init sound.
    Try setting the decay of the voice manually before triggering a note if no SD card with factory presets is available.
  • sound about right J il try when i get home. thanks for the fun build.
  • Right on Julian i got home after i got a new sd card and loaded up presets and da da dad aaaa it worked. so far seams to be in tip top shape now for the case i have a streat sign i bent that said wino xing i think im going to use that will see. thanks again and  i ordered buttons it was like 3 dollars. wasnt any thing.
