Sometimes when I'm in voice mode, I will click a step button to add or remove a beat and it doesn't register... This seems to happen most often on the first two step buttons, and most often when I happen to click a step button right as the active step is passing the step I'm pressing (although it also happens when playback is stopped, or when the active step is somewhere else). When I press again (or a few more times), the button press registers and the step is added. Maybe these ignored clicks aren't being ignored, but are actually registering as double clicks - so the step is turned on and then off again immediately.
This doesn't happen all the time - maybe once in every 20 presses or so. Often enough that it's noticeable, but not often enough to be unusable. Happens mostly on the first two step buttons, but it sometimes happens on other step buttons (only in voice mode) as well although much less frequently.
On these missed presses, the LED lights when I am pressing the button, so it seems the press is registered momentarily by the software, but when the button is released, the beat is not added (or removed as the case may be).
I don't think this is a hardware problem - my buttons seem to work fine physically. The same buttons seem to work perfectly in other modes.
