I save the current pattern and after restarting the LXR there is no pattern saved. Normaly in the first row stands "Pattern" or "Sound"...and Load or Save. In the second row the name of them. Sometimes the rows are reversed until another restart.
This is a feature, not a bug I should write this BIG in the quickstart guide.
Since at the moment loading takes a while, The newly loaded pattern is not started automatically. if you load a pattern, it will be loaded in the background, current pattern keeps playing. Then, when you manually switch to another pattern (performance mode, 8 select buttons) , the new loaded pattern will be activated.
I know it is quite hidden as it is now. But so far I had no better idea to deal with the long loading times of a pattern. An automatic change to the next bar, once the pattern is loaded is not really controllable in a musical sense. You don't want to think about when to press the button to omit a pattern change that happens 1 beat too late.
are files created on the SD card?
But it i want to load the saved pattern there is nothing.
Gesendet von meinem HTC One S mit Tapatalk 4
Could you try loading a pattern when the sequencer is not running?
i think so...you should write it more than big!!!
