I had this some weeks ago, but never found the cause or had it happen again. There seems to be a condition that causes the LXR init pattern after bootup to 'invert' the first steps substep pattern after power up sometimes.
If you look at the substep pattern of step 1 voice 1 (hold down shift while the step is selected) you will see that all substeps beside step 1 are active(.xxxxxxx). It should be the other way round (x.......). For now you will have to manually set/deactivate the substeps untill I've found the cause for this.
is this a permanent error? I had one user who reported this behaviour, but it seemed only to happen for the 1st preset kit on the sd card an as gone after he overwrote it.
Is it still only mono after you change the output routing and re-set it to stereo 1?
hi Julian, thanks for response... they are killing me at my new job so haven't had the toys(/weapons!) on for a while... think it was fixed by something I did so likely not a problem in the long term...
Will let you know but otherwise no news is good news...
I hate bugs that dont happen all the time! *grrr*
issue only appears without SDcard.
