Hi there,
today my kit arrived and i started building it. now i am at step 20, but i am facing a problem here. when i start up only one green led remains on : "voice 1" , not "voice mode" as it should. pressing the start button doesnt start the chase. chips are all placed correctly, mainboard is attached properly.
what else can i check??
edit: ok, found it. i mixed two ic's
cheers,
Ello
can you change voices?
cold solderjoint below the avr? maybe reflow the suspicious pins?
from the UI everything besides setting steps and starting the chaselight should work even without the mainboard attached.
and, btw: what a funky qr-code you have created.
I have to think about this. It makes no sense if all other voices are working. So the display works everywhere besides those 2 voices? Normally I'd say it's a connection problem between avr and the display, but then all display pages should be affected.
Unfortunately I have absolutely no time today. I'll get back to you tomorrow!
do i need to make a firmware update? i guessed thatit has the latest on it...
(picture shows which ic's where mixed)
Its unlikely but i had a similar probilem once with another device.
Can't hurt to check the soldering of the lcd connector and maybe reheat some of its solder joints.
have fun with the machine!
anyways-glad that it is finally working!
It could be either the display touching something or a bad solder joint that looses contact when under mechanical stress.
http://www.sonic-potions.de/sites/default/files/documents/FrontpanelSchematic.pdf
there are not that much components used for the MIDI IO
i build my kit today and i got the same problem as ello with the same LED screen as he posted on 20 september.
Then i start the lxr it says it already has the 0.23 firmware, What can i do to fix this?
Thx
Jens
http://www.sonic-potions.com/public/FIRMWARE.BIN
