Hi - looking forward to hopefully getting one of these things out of the upcoming batch. I had a couple of questions though:
1) If you adjust a parameter using an external midi controller, does the parameter name and value you're adjusting come up on the LXR's screen? I have a Shruthi, and it doesn't do this - it just adjusts the parameter in the background... I think having the parameter show up on the screen when it's being externally adjusted would be a pretty handy feature. Does the LXR do this?
2) In the MIDI out section of the manual, it says "The ability to send complete sequencer tracks with pitch information on different MIDI channels is
planned for a future release." Could someone elaborate a bit on these plans? I saw some posts about the work that's been done on MIDI out in the 2.3 firmware (ie: pitched outs for the drum tracks), but I'm hoping there may be plans to add a few sequencer tracks that aren't used for the drums - ie: tracks that you could record arbitrary MIDI information into with a keyboard or control surface or something, and replay that info out to, say, control an external synth, or send timed MIDI CC information. Would that be possible in a later firmware version? ...Is there enough memory for that?
3) (never mind this question - I just found the code repo on Github) has the LXR firmware source code been published? If not yet, will it be released at some point?
...and a suggestion: I'm kind of new to the hardware building/electronics thing, and have been learning a lot from building kits, but one thing that I think would be really helpful to turn building one of these into a better learning experience would be if the assembly instructions said something about what each part does, so you could learn a bit about what you're putting in and why it has to be there as you're putting the kit together... Instead of just "solder resistor A in slot B" type instructions. There are probably a ton of higher priority items to work on, but this would really add to the experience I think.
Thanks - great project, by the way. Really looking forward to playing with it.
...and on the "what's this component for" suggestion front, I'm not suggesting that the build instructions should provide exhaustive detail on what each part does, or that that should be the only way people learn. Just saying that everyone who builds one of these kits will read every line of the build instructions, and the more information that's in there, the more each of those people will learn while building. Even brief stuff like "these resistors control the brightness of the LEDs", or "this component is a crystal oscillator that helps generate LFO frequencies" - not too much detail, but something to give you some idea of what each component is for. If all you see is "solder this diode in here", then you won't necessarily have any idea why that component needs to be there.
Maybe just one sentence desribing the general functionality of the part and maybe a link/keyword to get more information. In the end I'm all for learning by kits since this is the way i've learned electronics, too
For full fledged midi recording/sequencing capabilities with extra tracks, there is just not enough available RAM
showing the edited midi parameters - could be done I think. I think I will put it on the nice to have list.
I thought about adding the detail screen to the display while using the pots to change a value (similar to the shruthi) and when I will include this, I think it would be easy to add the same to incoming CCs.
I'd recommend to get a cheap, compact pattern based sequencer for your synths instead, like the Alesis MMT8 or Yamaha RM1x. Hook up, sync and you're good to go...
:-c
This is quickly becoming an expensive habit.
